[gdal-dev] Impossible to open an ASRP dataset in java when gdalinfo/translate commands works
Assemat Pierre-Jean
pierre-jean.assemat at airbus.com
Wed Aug 23 03:32:41 PDT 2017
Dear all,
I work with GDAL 2.2.1 on Windows 7.
When I try to open an ASRP dataset in java with the following code :
Dataset resu = org.gdal.gdal.gdal.Open(filenameOrURL,
.gdal.gdalconst.gdalconst.GA_ReadOnly) ;
I have the following message :
ERROR 1: ISO8211 record leader appears to be corrupt.
and a null dataset is returned.
When I try to read this dataset in C++ whith gdalinfo or gdal_translate I do
have the same message but both commands ignore it and display full info or
perform translation...
Question :
What parameter/function should I call to have the same behavior in java ???
Thank you by advance for your help
Best regards
Pierre-Jean Assemat
View this message in context: http://osgeo-org.1560.x6.nabble.com/Impossible-to-open-an-ASRP-dataset-in-java-when-gdalinfo-translate-commands-works-tp5332236.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
