[gdal-dev] Impossible to open an ASRP dataset in java when gdalinfo/translate commands works
Even Rouault
even.rouault at spatialys.com
Wed Aug 23 03:44:09 PDT 2017
On mercredi 23 août 2017 03:32:41 CEST Assemat Pierre-Jean wrote:
> Dear all,
> I work with GDAL 2.2.1 on Windows 7.
> When I try to open an ASRP dataset in java with the following code :
> Dataset resu = org.gdal.gdal.gdal.Open(filenameOrURL,
> .gdal.gdalconst.gdalconst.GA_ReadOnly) ;
> I have the following message :
> ERROR 1: ISO8211 record leader appears to be corrupt.
> and a null dataset is returned.
> When I try to read this dataset in C++ whith gdalinfo or gdal_translate I do
> have the same message but both commands ignore it and display full info or
> perform translation...
> Question :
> What parameter/function should I call to have the same behavior in java ???
Pierre-Jean,
You can't without modifying the code. For historical reasons, the Java & Python bindings are
stricter than the C++ API, and will reject a non null dataset if an error has been emitted and
not cleared by the driver before it returns its dataset object.
A workaround is to add a CPLErrorReset() call before the "return poDS;" calls (there are
several ones) of SRPDataset::Open() in frmts/adrg/srpdataset.cpp
Another one is to alter in swig/include/gdal.i
#ifdef SWIGJAVA
%newobject Open;
%inline %{
static
GDALDatasetShadow* Open( char const* utf8_path, GDALAccess eAccess) {
CPLErrorReset();
GDALDatasetShadow *ds = GDALOpen( utf8_path, eAccess );
if( ds != NULL && CPLGetLastErrorType() == CE_Failure )
if ( GDALDereferenceDataset( ds ) <= 0 )
GDALClose(ds);
ds = NULL;
return (GDALDatasetShadow*) ds;
to
#ifdef SWIGJAVA
%newobject Open;
%inline %{
static
CPLErrorReset();
and regenerate the Java bindings.
A better solution would be to examine if the error is indeed legitimate, and possibly be more
tolerant to just issue a warning instead of an error.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170823/63ae75be/attachment.html>
