[gdal-dev] Call for discussion on RFC68: C++11 compilation mode
Tamas Szekeres
szekerest at gmail.com
Tue Aug 29 06:18:42 PDT 2017
Hi Even,
Yes, I'm planning to include msvc2015/2017 versions shortly.
Best regards,
Tamas
Sent from my iPhone
2017. aug. 14. dátummal, 19:02 időpontban Even Rouault <even.rouault at spatialys.com> írta:
> Hi Tamas,
> Unless I'm mistaken your gisinternals.com builds don't include MSVC 2015 currently. Right ? Do you have any plans to do so ? Currently the GDAL AppVeyor target uses SDKSs from gisinternals to do builds with a number of third-party libraries.
> Even
> > This is a call for discussion on RFC68 to set C++11 to be the minimum C++
> > language version for GDAL trunk. I've drafted the RFC based on work by
> > Mateusz.
> > https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> > There was initial discussions back in January of this year:
> > https://lists.osgeo.org/pipermail/gdal-dev/2017-January/thread.html#45786
> > Cheers,
> > -kurt
> > Engineer at Google
> Spatialys - Geospatial professional services
> http://www.spatialys.com
