[gdal-dev] Call for discussion on RFC68: C++11 compilation mode
Kurt Schwehr
schwehr at gmail.com
Tue Aug 15 09:59:05 PDT 2017
Hi Manuel,
Thanks for your thoughts! I added a link to the OTB RFC.
https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11?action=diff&version=10&old_version=9
-kurt
On Mon, Aug 14, 2017 at 6:44 PM, Grizonnet Manuel <Manuel.Grizonnet at cnes.fr>
wrote:
> Hi all,
> just want to share with you that we've got the same discussion recently in
> the orfeo toolbox project and we finally decide to move directly to c++14
> in the next release (6.2). It is a more recent standard with for sure less
> new features than in c++11 but yet useful. Moreover it does not change a
> lot the minimum compiler version (gcc min version is 4.9 I think for c++14).
> Will be glad to exchange also with you on strategies, pro/cons to then
> modernize the code.
> You can find more information about the discussion about c++11 vs c++14
> and few experiments which have been made with clang-tidy for OTB in the
> following RFComments and RFChanges:
> https://wiki.orfeo-toolbox.org/index.php/Request_for_
> Comments-36:_Move_OTB_to_C%2B%2B14
> Changes-95:_Compile_OTB_with_C%2B%2B14_by_default
> my 2 cents.
> Regards,
> Manuel GRIZONNET
> CNES - DCT/SI/AP - BPI 1219
> 18, avenue Edouard Belin
> 31401 Toulouse Cedex 09 - France
> Tel: +33 561 282 630 - Fax: +33 561 283 109
> *De :* gdal-dev [gdal-dev-bounces at lists.osgeo.org] de la part de Even
> Rouault [even.rouault at spatialys.com]
> *Envoyé :* lundi 14 août 2017 19:02
> *À :* Tamas Szekeres
> *Cc :* gdal-dev at lists.osgeo.org
> *Objet :* Re: [gdal-dev] Call for discussion on RFC68: C++11 compilation
> mode
> Hi Tamas,
> Unless I'm mistaken your gisinternals.com builds don't include MSVC 2015
> currently. Right ? Do you have any plans to do so ? Currently the GDAL
> AppVeyor target uses SDKSs from gisinternals to do builds with a number of
> third-party libraries.
> Even
> > This is a call for discussion on RFC68 to set C++11 to be the minimum C++
> > language version for GDAL trunk. I've drafted the RFC based on work by
> > Mateusz.
> > There was initial discussions back in January of this year:
> > https://lists.osgeo.org/pipermail/gdal-dev/2017-
> January/thread.html#45786
> > Cheers,
> > -kurt
> > Engineer at Google
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170815/067d0cfb/attachment.html>
