[gdal-dev] ogr2ogr from MySQL to FileGDB not working correctly in 2.x
Even Rouault even.rouault at spatialys.com
Tue Dec 19 04:17:36 PST 2017
On lundi 18 décembre 2017 21:26:26 CET Thanny wrote:
> I hope this is the correct place to post about this.
> There are several use cases I have for moving data into MySQL for
> processing, then exporting back out to ESRI FileGDB, using the ogr2ogr
> utility.
> Long story short, if I use a GDAL 1.x install, I'm able to export from MySQL
> to FileGDB without issue (at least mostly - the PROMOTE_TO_MULTI geometry
> type doesn't work, though it previously did).  If I use a GDAL 2.x install,
> the export works only for attribute data.  At the beginning of the export,
> this error is printed:
> ERROR 6: CreateGeomField() not supported by this layer.
> I've reproduced this with both polygon and point layers.
> As I said, I've used many different distributions, and all have this
> problem.  Here's the FileGDB line from "ogrinfo --formats":
>   FileGDB -vector- (rw+): ESRI FileGDB
> Any ideas on what I can do to narrow down where the problem is?
Thanny,
I believe this issue has been fixed in GDAL 2.2.3 per
FileGDB driver:
 * remove erroneous ODsCCreateGeomFieldAfterCreateLayer capability declaration (https://
github.com/OSGeo/gdal/pull/247)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171219/f9dd9699/attachment.html>
