[gdal-dev] GDAL-Kakadu 7.8 Performance Problems
jason.liu
jason.liu at spookfish.com
Tue Feb 14 19:17:57 PST 2017
Hi gdal-dev,
Does anybody else experience performance problems with GDAL-Kakadu 7.8?
In my test on a quad-core Linux box, the following code, which takes a
8100x4300 3-band RGB 200MB uncompressed tif and compress it using JP2KAK,
took 19 seconds to execute on average:
GDALAllRegister();
GDALDataset* srcDataset =
(GDALDataset*)GDALOpen("/home/jason.liu/00000783.tif", GA_ReadOnly);
char **papszOptions = NULL;
papszOptions = CSLSetNameValue( papszOptions, "QUALITY", "20" );
GDALDriver *driver = GetGDALDriverManager()->GetDriverByName("JP2KAK");
GDALDataset* destDataset =
driver->CreateCopy("/home/jason.liu/00000783.jp2",
srcDataset,
FALSE,
papszOptions,
NULL,
NULL);
if( destDataset != NULL ) {
GDALClose( (GDALDatasetH) destDataset );
GDALClose( (GDALDatasetH) srcDataset );
CSLDestroy(papszOptions);
Using the kdu_compress app which ships with Kakadu-7.8, the following
command line took 1.3 seconds to execute on average:
./kdu_compress -i /home/jason.liu/00000783.tif -o
The output jp2 sizes are similar (GDAL-Kakadu compresses down to 40MB, while
kdu_compress compresses down to 30MB). The number of jp2 tiles in both cases
are the same (one).
Changing GDAL settings such as JP2KAK_THREADS and GDAL_FORCE_CACHING seems
to make no significant difference to performance.
Any insights will be greatly appreciated.
Kind Regards
Jason
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Kakadu-7-8-Performance-Problems-tp5307960.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
