[gdal-dev] problem with HDF format
Luca Delucchi
lucadeluge at gmail.com
Wed Feb 15 02:29:51 PST 2017
Hi devs,
probably we found a problem with GDAL and HDF format, we are trying to
merge several MODIS tiles but we got a wrong "Corner Coordinates"
These are our input files
gdalinfo MOD11A1.A2012340.h29v05.005.2012342062359.hdf
GRINGPOINTLATITUDE.1=39.9958333333333, 39.9958333333333,
30.0041666666667, 30.0041666666667
GRINGPOINTLONGITUDE.1=143.594796204465, 156.637998651088,
138.5660967488, 127.027721580114
gdalinfo MOD11A1.A2012340.h28v05.005.2012342062414.hdf
GRINGPOINTLONGITUDE.1=130.54074741744, 143.583922543306,
127.018104673762, 115.479756825833
gdalinfo MOD11A1.A2012340.h28v04.005.2012342062356.hdf
GRINGPOINTLATITUDE.1=49.9958333333333, 49.9958333333333,
40.0041666666667, 40.0041666666667
GRINGPOINTLONGITUDE.1=155.572379857539, 171.116660974438,
143.601448808716, 130.556661758206
but using gdalbuildvrt, gdal_merge and gdalwarp we got a bigger upper
right value (173.313142 instead 171.116660974438), you can see our
tests here [0]
do you have any idea? is it a bug or feature?
[0] http://pastebin.com/KGYvFtfn
ciao
Luca
www.lucadelu.org
