[gdal-dev] Placemark With Two Geometries Is Not Processed
Kahly, Philip D. PHILIP.D.KAHLY at leidos.com
Wed Feb 15 08:21:09 PST 2017
Hey all,
I'm attempting to process some KML files from an outside source and
sometimes a <Placemark> will contain two <MultiGeometry> blocks.
GDAL will not process these placemarks: layer.GetNextFeature() will return
null, and GetLastErrorMsg() returns an empty string.
I've attached a sample file "broken.kml", along with two copies in which
one of the geometry blocks was deleted. GDAL processes these "part*.kml"
files correctly.
Google Earth uses the last geometry and ignores the others. Are there any
settings I could use to get GDAL to exhibit the same behavior?
Philip Kahly
Software Engineer
Philip.D.Kahly at Leidos.com
Type: application/vnd.google-earth.kml+xml
Desc: broken.kml
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170215/d6e4f3c0/attachment-0003.kml>
Desc: part1.kml
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170215/d6e4f3c0/attachment-0004.kml>
Desc: part2.kml
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170215/d6e4f3c0/attachment-0005.kml>
