[gdal-dev] Placemark With Two Geometries Is Not Processed
archgnulinux
philip.d.kahly at leidos.com
Wed Feb 15 09:08:01 PST 2017
Even Rouault-2 wrote
> From a quick try, I'd say that you must use the "old" KML driver. With the
> LIBKML driver, the
> reported geometry is the last one.
Thanks, I am using the "old" KML driver.
I tried to compile LIBKML for Windows awhile back but had quite a bit of
trouble.
I'll give it another try...
Do you know of any distributions of GDAL with LIBKML?
Philip
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Placemark-With-Two-Geometries-Is-Not-Processed-tp5308067p5308076.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
