[gdal-dev] Best vector driver?
Kurt Schwehr
schwehr at gmail.com
Thu Feb 16 07:10:14 PST 2017
Mateusz,
I have been meaning to write up a new RFC for the switch to C++11 as a
minimum in January and then the flu caught up with me. I will try to do
that in the next week or two. And I really appreciate all folks who
commented on that thread.
In my opinion, RFC 8 could use a lot of things and I only got through 2
documents that could feed into it last year (if I remember correctly). One
of which was about getting large buffers off of the stack (
http://goo.gl/vuA3D6). The other was a start on int bFoo -> bool bFoo (
https://goo.gl/hdzhXD
Things that I think should be discussed/added off the top of my head in no
particular order and only things before C++11. And I just overwhelmed
myself.
- When to use bool/true/false versus int/TRUE/FALSE/-1(MAYBE/UNKNOWN?).
Expand on https://goo.gl/hdzhXD
- namespaces
- IWYU
- Initializing vars and data members. ctor initializer lists
- Don't use goto
- Templates and inlining
- Defining one member per line
- clang-format
- C++ casting
- CPLString versus std::string
- Preferring const var to #define
- Making vars const when possible
- override, explicit, CPL_DISALLOW_COPY_ASSIGN
- Design for testability and what tests to have. e.g. I am working on an
in depth test of jp2kakdataset.cpp.
- static and dynamic analysis. cppcheck, clang static analyzier, compiler
warnings. How and when to tell the tools that they are being dumb
- Examples of good/helpful comments
- What to do about svn keywords and file permissions (e.g. python tests and
shellscripts being executable)
- When to use parens
- Prefer !.empty() and .empty(). When to use CPL_ARRAYSIZE
- Don't convert back to C strings for operations that are available in a
C++ string you already have
- ABS/MIN/MAX -> std::abs/std::min/std::max etc.
- When to use {} in if else (at least be consistent within a block)
- When to use a scope
- char *foo v. char foo[]
- When is it okay to have newlines in CPLDebug and CPLError
- When to use #if DEBUG_VERBOSE. Is it okay to check in commented out code?
After C++11:
- Avoid bare .*alloc/new and *free/delete
- NULL -> nullptr
- constexpr / static_assert
- std::initializer_list
On Thu, Feb 16, 2017 at 1:16 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 15 February 2017 at 17:27, Kurt Schwehr <schwehr at gmail.com> wrote:
> > Thanks for the pointers. I will do touchups on the driver tutorial as I
> go.
> > What's the cleanest way to setup the driver registration?
> > Should I be deriving from GDALDataset?
> Kurt,
> BTW, I'd have similar or related question.
> Which driver or part of the code is the latest/greatest in
> terms of the new C++ programming guidelines to look up to
> while writing new code for GDAL?
> Has there been any agreement on the overall C++ coding guidelines?
> Better, do we need the RFC8 [1] update?
> [1] https://trac.osgeo.org/gdal/wiki/rfc8_devguide
> Best regards
> Mateusz Loskot, http://mateusz.loskot.net
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170216/86a87575/attachment.html>
