[gdal-dev] Best vector driver?
Kurt Schwehr
schwehr at gmail.com
Thu Feb 16 08:44:22 PST 2017
Even,
If a format can have a combination of point, lines, and polygons in a
layer, should the layer class set wkbGeometryCollection? And if so, does
that imply Z is okay or not okay? I see there is
also wkbGeometryCollectionM and wkbGeometryCollectionZM, but
no wkbGeometryCollectionZ. And I see wkbGeometryCollection25D is old and
shouldn't be used, yes?
poFeatureDefn->SetGeomType(wkbGeometryCollection);
Thanks!
-kurt
On Thu, Feb 16, 2017 at 7:10 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Mateusz,
> I have been meaning to write up a new RFC for the switch to C++11 as a
> minimum in January and then the flu caught up with me. I will try to do
> that in the next week or two. And I really appreciate all folks who
> commented on that thread.
> In my opinion, RFC 8 could use a lot of things and I only got through 2
> documents that could feed into it last year (if I remember correctly). One
> of which was about getting large buffers off of the stack (
> http://goo.gl/vuA3D6). The other was a start on int bFoo -> bool bFoo (
> https://goo.gl/hdzhXD
> Things that I think should be discussed/added off the top of my head in no
> particular order and only things before C++11. And I just overwhelmed
> myself.
> - When to use bool/true/false versus int/TRUE/FALSE/-1(MAYBE/UNKNOWN?).
> Expand on https://goo.gl/hdzhXD
> - namespaces
> - IWYU
> - Initializing vars and data members. ctor initializer lists
> - Don't use goto
> - Templates and inlining
> - Defining one member per line
> - clang-format
> - C++ casting
> - CPLString versus std::string
> - Preferring const var to #define
> - Making vars const when possible
> - override, explicit, CPL_DISALLOW_COPY_ASSIGN
> - Design for testability and what tests to have. e.g. I am working on an
> in depth test of jp2kakdataset.cpp.
> - static and dynamic analysis. cppcheck, clang static analyzier, compiler
> warnings. How and when to tell the tools that they are being dumb
> - Examples of good/helpful comments
> - What to do about svn keywords and file permissions (e.g. python tests
> and shellscripts being executable)
> - When to use parens
> - Prefer !.empty() and .empty(). When to use CPL_ARRAYSIZE
> - Don't convert back to C strings for operations that are available in a
> C++ string you already have
> - ABS/MIN/MAX -> std::abs/std::min/std::max etc.
> - When to use {} in if else (at least be consistent within a block)
> - When to use a scope
> - char *foo v. char foo[]
> - When is it okay to have newlines in CPLDebug and CPLError
> - When to use #if DEBUG_VERBOSE. Is it okay to check in commented out
> code?
> After C++11:
> - Avoid bare .*alloc/new and *free/delete
> - NULL -> nullptr
> - constexpr / static_assert
> - std::initializer_list
> On Thu, Feb 16, 2017 at 1:16 AM, Mateusz Loskot <mateusz at loskot.net>
> wrote:
>> On 15 February 2017 at 17:27, Kurt Schwehr <schwehr at gmail.com> wrote:
>> > Thanks for the pointers. I will do touchups on the driver tutorial as
>> I go.
>> > What's the cleanest way to setup the driver registration?
>> > Should I be deriving from GDALDataset?
>> Kurt,
>> BTW, I'd have similar or related question.
>> Which driver or part of the code is the latest/greatest in
>> terms of the new C++ programming guidelines to look up to
>> while writing new code for GDAL?
>> Has there been any agreement on the overall C++ coding guidelines?
>> Better, do we need the RFC8 [1] update?
>> [1] https://trac.osgeo.org/gdal/wiki/rfc8_devguide
>> Best regards
>> Mateusz Loskot, http://mateusz.loskot.net
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170216/d6f611dd/attachment-0001.html>
