[gdal-dev] Building GDAL with PROJ4 in a non-standard location?
Emmanuel d'Angelo emmanuel.dangelo at pix4d.com
Thu Feb 16 07:55:42 PST 2017
Oops, I hadn't inferred that.
Thanks Even!
Emmanuel
[image: Pix4D] <http://pix4d.com/>    Emmanuel d'Angelo | Model Team
Technical Lead
EPFL Innovation Park *| Building F | *1015 Lausanne, Switzerland
t. +41 21 552 05 96
 *https://pix4d.com <https://pix4d.com/> | * *emmanuel.dangelo at pix4d.com
<emmanuel.dangelo at pix4d.com>*
*[image: Twitter] <https://twitter.com/pix4d>[image: Facebook]
<https://www.facebook.com/Pix4D/>[image: LinkedIn]
<https://www.linkedin.com/company/pix4d>[image: YouTube]
<https://www.youtube.com/channel/UCXHBqjCbv1wj_-itfvpVNIA?sub_confirmation=1>*
2017-02-16 16:51 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> On jeudi 16 février 2017 16:48:57 CET Emmanuel d'Angelo wrote:
> > Hi everyone,
> > I'm experimenting with a C++ package manager (conan.io for interested
> > folks) to correctly setup my project and its dependencies.
> > In this experiment, I'm trying to wrap GDAL and build GDAL 2.1.1 using a
> > PROJ4 library that was put in a non-standard location by the package
> > manager. When I had a look at the configure.in file, I could find an
> option
> > to specify the path to PROJ4 install directory, but that is only set when
> > using the option --with-static-proj4.
> > Is there a way to pass the path to a dynamic library of PROJ4 when
> building
> > GDAL?
> Emmanuel,
> Yes, with that very same option. The "static" in --with-static-proj4
> refers to a a static/dynamic linking done at build time rather than the
> default behaviour which is to use dlopen() / LoadLibrary() metchanisms at
> runtime.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170216/0b9a0060/attachment.html>
