[gdal-dev] Conformity of GeoPackage rasters generated by GDAL
Even Rouault even.rouault at spatialys.com
Thu Feb 23 02:49:25 PST 2017
Thanks to interoperability tests led by Brian Osborn from the sample GeoPackage with
elevation data I generated, he spotted a more general issue with the registration of raster
tiles that can cause spatial registration to be wrong when GDAL generated raster .gpkg are
read by other implementations (to give full credit i think Brad Hards noticed this earlier)
I've fixed the issue in trunk and 2.1 branch per
https://trac.osgeo.org/gdal/ticket/6826
So if you need to ensure interoperability with other implementations, you'd better fetch the
fix and regenerate your productions.
Note: You don't necessarilty need to regenerate the whole .gpkg, but you need to correct the
content of gpkg_tile_matrix, so that for zoom_level = Z > 0 :
matrix_width(Z) = 2^Z * matrix_width(zoom_level=0)
matrix_height(Z) = 2^Z * matrix_height(zoom_level=0)
This is only when using no overview or power-of-two overviews. For non power-of-two
overviews (which is an extension), I think there might be still issues.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170223/0a434e69/attachment.html>
