[gdal-dev] ogr2ogr polygon cleanup algorithm?
Even Rouault
even.rouault at spatialys.com
Tue Feb 28 15:36:07 PST 2017
On mardi 28 février 2017 17:25:51 CET TazMainiac wrote:
> Hi All,
> When I use ogr2ogr to process a shape file (into KML for examle) that has
> "invalid" polygons (self-intersections or other problems) in it, it "cleans
> them up", such that they are valid. Is there a description anywhere of
> what algorithm it's using to do this cleanup?
Hum, there's not really such a cleanup algorithm. When writing a shapefile, there's some
"topological analysis" to figure out which rings of a (multi)polygon are inside others, so as to
respect the shapefile specification, but that's all. I'd be surprised that self-intersections of a
ring are corrected for example.
if you want to explicitly remove invalid geometries, you can do something like:
ogr2ogr out.shp in.kml \
-sql "SELECT * FROM input_layer WHERE ST_IsValid(geometry)" -dialect SQLite
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170301/be9140c8/attachment.html>
