[gdal-dev] OSM - delineation of rivers
Simon Lyngby Kokkendorff silyko at gmail.com
Mon Jan 2 13:14:23 PST 2017
Hi Andre,
  Thanks for the tip - I guess there's a lot more that can be done with the
overpass API than I'm using right now!
In my case I need to process a lot of square regions (with random center
coords). Will try to see if the "river problem" can be fixed by fetching a
larger region than needed, or perhaps doing a more advanced query than the
simple bounding box one, I'm doing now. Should really look a bit more into
the API!
Cheers,
Simon
On Mon, Jan 2, 2017 at 7:12 PM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 01.01.2017 um 22:52 schrieb Simon Lyngby Kokkendorff:
>> And indeed - worked like a charm when I ran ogr2ogr on a pbf file
>> containing the whole of England. The River Thames is represented nicely,
>> as
>> was the case with osm2pgsql. Was surprisingly fast also compared to
>> osm2pgsql!
>> So definitely a "too small area" issue!
> Alternatively, you can look up the river relation at
> http://wiki.openstreetmap.org/wiki/UK_Waterway_Relations and Query only
> for that, but complete:
> relation(2263653);>>;
> out;
> HTH,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170102/33cf201d/attachment.html>
