[gdal-dev] 1.11 OGR_F_SetFieldDouble() then OGR_F_GetFieldAsDouble() always returns zero
Nik Sands
nik at nixanz.com
Mon Jan 2 16:24:32 PST 2017
Hi List. I'm using GDAL/OGR 1.11 in an Objective-C (iOS)
application.
I'm attempting to store double values in an OFTReal field using
OGR_F_SetFieldDouble() and then to retrieve these values later using
OGR_F_GetFieldAsDouble(). If I retrieve the value immediately, it
works fine. However, after closing and re-opening the
datasource/layer, I only ever get zero (0.0) values. I am running
syncToDisk() after writing values.
I'm using the Esri Shapefile driver.
The code used for writing is:
i = OGR_F_GetFieldIndex(feature.feature, "Time");
if ( i > -1 ) {
OGR_F_SetFieldDouble(feature.feature, i, [[NSDate date]
timeIntervalSince1970]);
NSLog(@"Wrote %ld Date %f", OGR_F_GetFID(feature.feature),
OGR_F_GetFieldAsDouble(feature.feature, i));
// LOGS EXPECTED NON-ZERO VALUE HERE
OGR_L_SyncToDisk(_layer);
The code used for reading after re-opening the data source is:
i = OGR_F_GetFieldIndex(_feature, "Time");
if ( i > -1 ) {
NSLog(@"Got %ld Cell Date: %f", OGR_F_GetFID(_feature),
OGR_F_GetFieldAsDouble(_feature, i));
// ALWAYS LOGS 0.0 HERE (logs a valid FID)
Am I doing anything obviously wrong? Any ideas why this is not
working as I expected?
Let me know if there is any more code that would make it more clear.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170103/8737f5a7/attachment.html>
