[gdal-dev] C++11 timeline
Kurt Schwehr schwehr at gmail.com
Thu Jan 5 09:32:57 PST 2017
Even responded while I was trying to write up something, so I'm going to
stop writing and send :)
Howard,
Thanks for the thoughts.  I believe we are thinking along the same lines.
All,
After time for comments, I plan to write up an RFC for the initial strategy
that is explicit about assumptions.
Please correct me if you think I'm wrong/missing anything.  Especially when
it comes to non-linux / mac builds.
Useful references:
http://en.cppreference.com/w/cpp/compiler_support
https://en.wikipedia.org/wiki/List_of_compilers#C.2B.2B_compilers
Current explicit supported compilers:
- MS VC9
- MS VC12
- MS VC13
- MinGW 32 (this is old)
- MinGW 64 (newer)
- clang >= 3.0?
- gcc >= 4.6.3.  Even said 4.4
Best effort supported compilers:
- SunPro/Oracle C++ >= ?
- Intel >= ?
My guess at our new situaltion
- MS >= VC13 (I am confused by their version numbers)
- MinGW 32 (newer)
- MinGW 64 (newer)
- clang >= 3.3
- gcc >= 4.8
- SunPro >= ?
- Intel >= ?
On Thu, Jan 5, 2017 at 9:26 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > What is the list of compilers that GDAL actively and accidentally
> supports?
> Currently, at least:
> GCC >= 4.4 (actually must be 4.1 since this is what ancient mingw uses)
> clang >= 3.something (3.0 probably)
> VS >= 2008
> ICC 15 probably
> One aspect is to also consider the various analyzers used. I think
> cppcheck has only partial C++11 support. I'd guess Coverity Scan should
> have decent C++11 support but this is just a guess. CLang Static Analyzer
> should likely work just fine with the C++11 supported by the underlying
> clang compiler
> > How will that be impacted by a C++11 requirement?
> GCC 4.8 is needed for C++11 I think. There are folks using recent GDAL on
> older distros like Ubuntu 12.04 (which ships with gcc 4.6). I guess they
> could switch to adding a PPA with a more recent toolchain.
> For Visual Studio depends on the features we use. Would be good to have
> VS2013 or even 2012. I'm CC'ing Jürgen Fischer to know if he has plans
> regarding of the compiler version that will be used for OSGeo4W / QGIS 3.0
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170105/b3e4e722/attachment.html>
