[gdal-dev] Question on block size in the kakadu driver
Kurt Schwehr
schwehr at gmail.com
Thu Jan 5 09:37:24 PST 2017
Even,
Thanks! I'm working on a change that will do:
nBlockXSize = std::min(nRasterXSize, 2048);
nBlockYSize = std::min(nRasterYSize, 128);
Getting a performance monitoring system setup is definitely on my todo
list, but sadly still down a ways.
On Thu, Jan 5, 2017 at 7:40 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 5 janvier 2017 07:18:45 CET Kurt Schwehr wrote:
> > Frank, Even or anyone with experience with jp2k block sizes,
> > Any chance you could comment on the change I proposed here?
> > https://trac.osgeo.org/gdal/ticket/6764
> > Is it reasonable to change this:
> > if( nRasterXSize >= 2048 )
> > nBlockXSize = 2048;
> > else
> > nBlockXSize = nRasterXSize;
> > if( nRasterYSize >= 256 ) // <- 256
> > nBlockYSize = 128; // <- 128 ???
> > else
> > nBlockYSize = nRasterYSize;
> > Into:
> > or
> > nBlockYSize = std::min(nRasterYSize, 256)
> > Neither of those is the same behavior and the the jump from 256 back to
> 128
> > is not explained in the revision log. Which behavior will have better
> > performance for a average case or will it matter?
> The code is a bit weird indeed. But the block size of smallish datasets
> has no real importance, so if you find it more reasable, switching the
> condition to if ( nRasterYSize >= 128 ) (or the equivalent std::min())
> should have no adverse consequences.
> Block size in the case of JPEG 2000 is really hard to come with. A smarter
> block size logic would depend on JPEG 2000 tiling, presence of precincts,
> etc... This also could depend on the read pattern. Would deserve extensive
> testing to come out with the ideal formula... In the case of JP2KAK,
> there's also a IRasterIO() implementation that causes the block size to not
> be used at all in typical read scenarios.
> > The difference will be
> > between 262K cells or 524K cells. With doubles, that will be 2 or 4 MB
> for
> > a single block from one band.
> FWIIW, JPEG2000 doesn't support double (at least not in the base standard)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170105/594f5ca4/attachment-0001.html>
