[gdal-dev] How does OGRFeature::GetFieldAsDouble handle NULL values
Paul Meems
bontepaarden at gmail.com
Thu Jan 5 13:36:53 PST 2017
We're using GDAL v2.1.2 on Windows.
We use the GDAL library with MapWinGIS to connect to a PostGIS database.
When the PostGIS table has NULL values in integer, numeric or double fields
and that data is read the returned values are 0 (zero), which is unexpected
by us.
We use Feature->GetFieldAsDouble() and Feature->GetFieldAsInteger().
Am I correct that these function return 0 when the database value is NULL?
If not our implementation is wrong and I need to continue my search.
The documentation
http://www.gdal.org/classOGRFeature.html#ab8a57c94e8bb8ffac5e7048d896254b4
doesn't say either way.
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170105/0d10ca1a/attachment.html>
