[gdal-dev] PostGIS with more than one geometry column per table | R-Trees
Alexander.Berdnikow at mettenmeier.de Alexander.Berdnikow at mettenmeier.de
Fri Jan 13 07:54:55 PST 2017
sorry, there is a half copy of this post in the forum already, which was
not accepted by the maillist.
I translated a Table (Feature) of a PostGIS Database to a GeoPackage with
GDAL. The Feature has two Linestring Geometries in the PostGIS DB. One
geometry with exact positions of the network and one overwiew geometry
which may have just rough positions. Often the overwiew ist just a copy of
the exact positions, but sometimes it differs.
After translation of the feature to GeoPackage everything seems fine, but
in the GeoPackage I have only one Linestring geometry. It is listed in the
gpkg_geometry_columns.
My question is, which of the two geometries was translated to the
GeoPackage? What happens to the other geometries of the feature in the
translation process?
I've read about the solution of the multiple geometries issue in
GeoPackage in the GP-specification. Does GDAL support this in the
translation process (maybe with a special option?)?
______
A first solution for us was to use a View Schema, where each feature has
only one geometry. Now I have two schemas in the PostGIS DB and they were
both translated. Two questions about it:
- Is there a command to say which schemas to translate and which not? My
command is now as follows:
ogr2ogr -f GPKG data.gpkg PG:"host=localhost user=user dbname=data
password=pw"
I found options to select tables, but there are hundreds of tables in the
schema I am interested in. Maybe there is an easy  possibility to say
"take only schema x"? Did not found it in the list
http://www.gdal.org/ogr2ogr.html
- How can I supress the building of r-tree tables? There are virtually
thousands of them in the created geopackage.
Regards,
Alexander
_______________________________________________________
Mettenmeier GmbH
Sitz der Gesellschaft: 33100 Paderborn
Geschaeftsfuehrung: Ulrich Mettenmeier, Dirk Weidemann
Handelsregister: Amtsgericht Paderborn B 1114
USt.-ID: DE 811 324 124
Steuer-Nr.: 339/5873/3133
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170113/13df93a3/attachment-0001.html>
