[gdal-dev] PostGIS with more than one geometry column per table | R-Trees
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Mon Jan 16 06:47:00 PST 2017
Alexander Berdnikow wrote
> http://www.geopackage.org/modeling_guidelines.html
> Use Case 2 describes a way how to handle multiple geometries in
> GeoPackage.
Then you convert the first geometry with all the attributes into GeoPackage
and then add another layer with a command like
-Jukka Rahkonen
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-PostGIS-with-more-than-one-geometry-column-per-table-R-Trees-tp5303398p5303624.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
