[gdal-dev] Question about .aux.xml sidecar file handling...
Carl Godkin cgodkin at gmail.com
Thu Jan 19 06:15:15 PST 2017
On Thu, Jan 19, 2017 at 3:17 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 18 janvier 2017 06:55:49 CET Carl Godkin wrote:
> > Hi,
> > I have a geological map in a pair of files called USGS.tif and
> > USGS.tif.aux.xml
> > The XML seems to have ground control points (<SourceGCPs>) and a
> geographic
> > coordinate system (<SpatialReference>)
> GDAL .aux.xml files do no have <SourceGCPs> or <SpatialReference>
> elements, so it looks like this .aux.xml file is a USGS specific one
> (yikes!)
> The names understood by GDAL are <GCPList> and the SRS is stored as a
> Projection attribute of <GCPList>
Hi Even & Jukka,
This folder on my Google drive contains the two folders.  They are not
private or anything so please feel free to test with them if you need them:
https://drive.google.com/drive/folders/0B-pQ1UXElObET3Nfbk9qQ1VDZWc
Thanks a lot,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170119/f88ee114/attachment-0001.html>
