[gdal-dev] FW: Strange results of simple polygonising
Casper Børgesen (CABO) CABO at NIRAS.DK
Fri Jan 20 00:31:17 PST 2017
I have looked at the special case of a raster combining situation 3 and 4 below:
3 + 4:
The polygoniser handles this fine by return a result with two separate polygons.
For easier reference, I have included the WKT of the 4 + 1 situations and their results:
1:
Input:   POLYGON ((1 1,3 1,3 2,2 2,2 3,3 3,3 2,4 2,4 4,1 4,1 1))
Result: POLYGON ((1 4,1 1,3 1,3 2,2 2,2 3,3 3,3 2,4 2,4 4,1 4))
2:
Input:   POLYGON ((1 1,4 1,4 3,3 3,3 2,2 2,2 3,3 3,3 4,1 4,1 1))
Result: POLYGON ((1 4,1 1,4 1,4 3,3 3,3 2,2 2,2 3,3 3,3 4,1 4))
3:
Input:   POLYGON ((1 1,4 1,4 4,2 4,2 3,3 3,3 2,2 2,2 3,1 3,1 1))
Result: POLYGON ((2 4,2 3,1 3,1 1,3 1,4 1,4 4,2 4),(2 3,2 2,3 2,3 3,2 3))
4:
Input:   POLYGON ((1 4,1 2,2 2,2 3,3 3,3 2,2 2,2 1,4 1,4 4,1 4))
Result: POLYGON ((1 4,1 2,2 2,2 1,4 1,4 4,1 4),(2 3,3 3,3 2,2 2,2 3))
3 + 4:
Input:   MULTIPOLYGON (((1 2,2 2,2 4,1 4,1 2)),((2 1,4 1,4 5,2 5,2 4,3 4,3 2,2 2,2 1)))
Result: POLYGON ((1 4,1 2,2 2,2 4,1 4)) + POLYGON ((2 5,2 4,3 4,3 2,2 2,2 1,3 1,4 1,4 5,2 5))
I have performed the tests on both GDAL 1.11 and GDAL 2.1 and both return the same results.
Can anyone confirm my observations?
Background: The 4 situations are very simplified versions of much more complicated polygons, where the problem occurs. If I save the results from situation 3 or 4 to a shape file with ogr, the hole in the results are converted to an exterior ring in a separate polygon thus creating overlapping results.
Regards, Casper
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Casper Børgesen (CABO)
Sent: 19. januar 2017 13:26
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Strange results of simple polygonising
I have four simple rasters that I would like to polygonise:
1:
2:
3:
4:
It's the same shape, just rotated 90, 180, 270 degrees. The resulting polygons for 1 and 2 are simple polygons without holes, where the results for 3 and 4 are polygons with a hole intersecting the exterior ring. Thus 3 and 4 results in invalid geometries with self-intersection.
Is this the intended behavior of the polygoniser?
Regards, Casper
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/ae86f06e/attachment.html>
