[gdal-dev] java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.Dataset_SWIGUpcast(J)J
Vlad
vladimir.sandoval at yandex.com
Tue Jan 24 08:28:51 PST 2017
I have a clean build on RHEL of Gdal 2.1.2. Java app (as shaded jar) with
the Maven 2.1.0 dependency throws:
Exception in thread "main" java.lang.UnsatisfiedLinkError:
at org.gdal.gdal.gdalJNI.Dataset_SWIGUpcast(Native Method)
at org.gdal.gdal.Dataset.<init>(Dataset.java:20)
at org.gdal.gdal.gdal.Open(gdal.java:590)
Reading, I find this is due to a SWIG version incompatibility. SWIG version
used for the RHEL build was 1.3.40.
Anybody know what SWIG version the Maven 2.1.0 jar was built with? Also,
assuming someone knows, I can just follow Even's procedure here
http://osgeo-org.1560.x6.nabble.com/gdal-dev-GDAL-Java-Bindings-Unable-to-use-same-jar-on-linux-and-windows-td5243795.html
to get a "good" build?
View this message in context: http://osgeo-org.1560.x6.nabble.com/java-lang-UnsatisfiedLinkError-org-gdal-gdal-gdalJNI-Dataset-SWIGUpcast-J-J-tp5304636.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
