[gdal-dev] Remove projection information from GeoTiff
Neumann, Andreas a.neumann at carto.net
Thu Jan 26 02:13:38 PST 2017
Is there a way to remove the projection information from a GeoTiff file
without having to copy the whole file with gdal_translate and use the
BASELINE Profile that doesn't write GeoTIFF header?
Something along the lines of the gdal_edit -unsetgt option, e.g. an
-unsetprj option?
Thanks for any ideas,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170126/2f72bcf1/attachment.html>
