[gdal-dev] Remove projection information from GeoTiff
Even Rouault
even.rouault at spatialys.com
Thu Jan 26 02:21:31 PST 2017
On jeudi 26 janvier 2017 11:13:38 CET Neumann, Andreas wrote:
> Hi,
> Is there a way to remove the projection information from a GeoTiff file
> without having to copy the whole file with gdal_translate and use the
> BASELINE Profile that doesn't write GeoTIFF header?
> Something along the lines of the gdal_edit -unsetgt option, e.g. an
> -unsetprj option?
Andreas,
Actually you can use -a_srs "" or -a_srs None. I've just extended the doc of the -a_srs option to
mention that.
Note: as most edit in place operations on TIFF, the previous coordinate system erased that
way will remain in a ghost state inside the TIFF file. You can see it with an hexadecimal editor.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170126/e0f51f8e/attachment.html>
