[gdal-dev] Windows line endings
Even Rouault even.rouault at spatialys.com
Thu Jan 26 07:45:30 PST 2017
On jeudi 26 janvier 2017 16:41:20 CET Tomasz Sawka wrote:
> Hello
> Is there an option in GDAL to set line endings for text files like ESRI hdr
> or GeoTiff ftw files?
Not for those cases.
On the OGR side, this can be available in some drivers, but I'm not aware of much
configuration currently available on the GDAL side.
> We are working on Windows and some software we use expects CRLF and gets
> confused when only LF is used. I was looking in global options but could
> not find suitable switch.
There is none indeed.
> I create files using gdalwarp from  C++ API. Any
> tips appreciated.
> Best Regards
> Tomasz Sawka
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170126/7ca17c1c/attachment.html>
