[gdal-dev] WFS-T using OGR
Even Rouault
even.rouault at spatialys.com
Fri Jan 27 02:50:04 PST 2017
On vendredi 27 janvier 2017 10:20:36 CET Ahmed Tolba wrote:
> I followed the example here. http://www.gdal.org/ogr_apitut.html
> How would I set a transaction through a webserver.
> The tutorial only shows how to do it on disk.
> Is it possible to write a transaction WFS-T using a server call ?
Yes WFS-T (1.0.0 or 1.1.0 only. code has not yet been upgraded to support WFS-T 2.0.0 as far
as I remember) is supported in a similar way as editing other datasources.
> m_wfs_t =
> OGRSFDriverRegistrar::Open("http://192.168.139.128/cgi-bin/tinyows.exe?SERV
> ICE=WFS&VERSION=1.0.0",true);
Prefix the endpoint with WFS:
so
Open("WFS:http://192.168.139.128/cgi-bin/tinyows.exe?SERVICE=WFS&VERSION=1.0.0",
true)
OGRFeature *poFeature;
> poFeature = OGRFeature::CreateFeature( poLayer->GetLayerDefn() );
> poFeature->SetField( "Name", "poiAhmed" );
> OGRPoint pt;
> pt.setX( 120 );
> pt.setY( 240 );
> poFeature->SetGeometry( &pt );
> if( poLayer->CreateFeature( poFeature ) != OGRERR_NONE )
> printf( "Failed to create feature in shapefile.\n" );
> exit( 1 );
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170127/b3fe9a35/attachment.html>
