[gdal-dev] WFS-T using OGR
Ahmed Tolba
Ahmed.Tolba at schiebel.net
Fri Jan 27 02:59:21 PST 2017
Hi
Thanks for your answer.
I tried to do what you suggested, but I get " Can not insert the feature, because we didn't manage to parse the .XSD schema "
Here is my code:
m_wfs_t = OGRSFDriverRegistrar::Open("WFS:http://192.168.139.128/cgi-bin/tinyows.exe?SERVICE=WFS&VERSION=1.0.0",true);
OGRLayer *poLayer;
poLayer = m_wfs_t->GetLayerByName("tows:poi_ais");
OGRFeature *poFeature;
poFeature = OGRFeature::CreateFeature( poLayer->GetLayerDefn() );
poFeature->SetField( "Name", "poiAhmed" );
poFeature->SetFID(1000);
poFeature->SetField("speed",10);
OGRPoint pt;
pt.setX( 120 );
pt.setY( 240 );
poFeature->SetGeometry( &pt );
if( poLayer->CreateFeature( poFeature ) != OGRERR_NONE )
std::cout <<"error creating a feature"<<endl;
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, January 27, 2017 11:50 AM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Cc: Ahmed Tolba
Subject: Re: [gdal-dev] WFS-T using OGR
On vendredi 27 janvier 2017 10:20:36 CET Ahmed Tolba wrote:
> I followed the example here. http://www.gdal.org/ogr_apitut.html
> How would I set a transaction through a webserver.
> The tutorial only shows how to do it on disk.
> Is it possible to write a transaction WFS-T using a server call ?
Yes WFS-T (1.0.0 or 1.1.0 only. code has not yet been upgraded to support WFS-T 2.0.0 as far as I remember) is supported in a similar way as editing other datasources.
> m_wfs_t =
> OGRSFDriverRegistrar::Open("http://192.168.139.128/cgi-bin/tinyows.exe?SERV
Prefix the endpoint with WFS:
so
Open("WFS:http://192.168.139.128/cgi-bin/tinyows.exe?SERVICE=WFS&VERSION=1.0.0", true)
> OGRPoint pt;
> pt.setX( 120 );
> pt.setY( 240 );
> printf( "Failed to create feature in shapefile.\n" );
> exit( 1 );
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170127/ddbf72dd/attachment-0001.html>
