[gdal-dev] VRT file with cutline behaves strangely with tiff with overviews
Even Rouault even.rouault at spatialys.com
Sat Jul 1 11:32:18 PDT 2017
> Is this a known and expected behavior of the VRT-format?
> I really want to keep using the vrt-file since it is only 700kb instead of
> the tiff-file which is 63MB and I will be doing more calculations later on,
> which also result in new files.
> If needed I can send my input files.
Please open a ticket about that, with the links to the files to reproduce.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170701/305fab52/attachment.html>
