[gdal-dev] VRT file with cutline behaves strangely with tiff with overviews
Paul Meems
bontepaarden at gmail.com
Tue Jul 4 23:42:02 PDT 2017
I've created a ticket: https://trac.osgeo.org/gdal/ticket/6954 and added
some sample data to reproduce.
Thanks,
Paul
2017-07-01 20:32 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> > Is this a known and expected behavior of the VRT-format?
> > I really want to keep using the vrt-file since it is only 700kb instead
> of
> > the tiff-file which is 63MB and I will be doing more calculations later
> on,
> > which also result in new files.
> > If needed I can send my input files.
> Please open a ticket about that, with the links to the files to reproduce.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170705/52bb7f47/attachment.html>
