[gdal-dev] Bus error on gdal.Open
Grégory Bataille
gregory.bataille at gmail.com
Tue Jul 25 03:17:14 PDT 2017
that's the part where I'm not sure. For simplicity sake, I'm sourcing the
GDAL install from osgeo4mac
https://github.com/OSGeo/homebrew-osgeo4mac
It's super practical. And since I'm not big on C compiling (and setup of
compilation), that's helpful. But then I don't know what it does.
Also, those 2 lines are warning. I don't know if they are the one causing
the bus error and the subsequent crash of the console.
But you are right that I seem to have several libtiff
4.0.8
4.0.7_3
4.0.7_2
4.0.7_1
4.0.7
I tried to remove gdal, and the python bindings and reinstall from scratch
again, but same result.
What I really can't understand is that ipython and ipython launched through
django, in the same virtualenv, give different results
Gregory Bataille
On Tue, Jul 25, 2017 at 11:37 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 25 juillet 2017 11:00:36 CEST Grégory Bataille wrote:
> > Hi everyone,
> > I have the strangest issue and I don't know how to address it.
> > I'm running on a *mac*. I have *gdal 2.2.0* installed on the system.
> > I have a python 3.5.2 *virtualenv* (same behavior in 3.6.1)
> > inside I have a number of libraries, including django and the *GDAL
> > bindings*.
> > If from this virtualenv I open a *ipython* console and try to gdal.Open a
> > TIFF, *all works well*.
> > If I open a *django console* (django manage.py shell) in this virtualenv
> > and try to perform the same operation, I get
> > > TIFFReadDirectory: Warning, Unknown field with tag 42112 (0xa480)
> > > encountered.
> > > TIFFReadDirectory: Warning, Unknown field with tag 42113 (0xa481)
> > > encountered.
> This is weird. Those are the TIFFTAG_GDAL_METADATA and TIFFTAG_GDAL_NODATA
> tags that are defined by the GDAL GTiff driver. So if you open something
> with GDALOpen() that shouldn't happen normally
> I'm wondering if in your whole system you don't have several libtiff
> versions mixed together. How is your GDAL configured ? If it uses internal
> libtiff and libgeotiff, make sure to ./configure --with-rename-internal-libtiff-symbols
> and --with-rename-internal-libgeotiff-symbols so that the internal
> libtiff and libgeotiff in GDAL do not collide with other.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/b7d5fe6a/attachment.html>
