[gdal-dev] Is Internal JPEG compression allowed on RGBA GeoTIFF?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Jul 25 06:33:50 PDT 2017
Dear all,
I was always thinking that JPEG doesn't support transparency so that it
would not be possible to convert a 4 bands GeoTIFF using JPEG compression
(without using internal binary mask).
However, I just did a gdal_translate -ot byte -scale -CO COMPRESS=JPEG
4bands.tif rgba_jpeg.tif and it "worked".
The gdalinfo output on the new file reports 4 bands dataset with
Gray,Green,Blue,Alpha colors.
Does the TIFF specification allows that?
I still have to read it again to check if/how alpha and JPEG compression
are related, but I'm wondering if you have any feedback on this topic in
order to understand if a "standard" GeoTIFF reader should be able to deal
with that or not and how to deal with the Alpha band (which at this point
would be a Lossy band, containing artifacts).
Feedbacks are welcome.
Regards,
Daniele
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/112cee76/attachment-0001.html>
