[gdal-dev] Grids in OpenFileGDB databases?
Even Rouault even.rouault at spatialys.com
Tue Jul 25 12:33:01 PDT 2017
Carl,
there have been a few successful efforts last year to prototype decyphering of rasters
in .gdb, so it is now a matter of creating a proper GDAL driver from those findings. Sponsors
could be welcome.
Looking at the dataset you point too, it seems that the grids are provided as XYZ in the
ASCII directory
You can get the contents of each .gdb with:
ogrinfo -ro  -al UKCS_Multi_Sat_Gravity_Data/ESRI/ESRI_Grids.gdb/a00000004.gdbtable
ogrinfo  -ro -al UKCS_Multi_Sat_Gravity_Data/GIS/GIS.gdb/a00000004.gdbtable
Grids are the features with "Definition (String) = <DERasterDataset..."
Even
> Hi,
> I just came across a GDB that contains two "MultiPolygon" layers plus about
> ten more layers that are apparently grids.
> Does OpenFileGDB provide any access to these layers?  I'm using GDAL 2.2.1.
> I think the GDB has grids because I can see them in ArcGIS Explorer, but
> "ogrinfo --ro GIS.gdb" does not list them.
> (In case anyone is interested, the data is from here:
> https://itportal.decc.gov.uk/web_files/gis/Round30Data/Getech/UKCS_Multi_Sat
> _Gravity_Data.zip
> and is referenced from here:
> http://data-ogauthority.opendata.arcgis.com/datasets
> Both the ESRI and GIS sub-directories contain .gdb sub-directories.  The
> ESRI sub-directory GDB apparently contains only grids; the GDB in the GIS
> sub-directory has two MultiPolygon layers and about ten grids.)
> Thanks for any suggestions,
> carl
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/72d252c4/attachment.html>
