[gdal-dev] Grids in OpenFileGDB databases?
Carl Godkin
cgodkin at gmail.com
Tue Jul 25 12:14:10 PDT 2017
I just came across a GDB that contains two "MultiPolygon" layers plus about
ten more layers that are apparently grids.
Does OpenFileGDB provide any access to these layers? I'm using GDAL 2.2.1.
I think the GDB has grids because I can see them in ArcGIS Explorer, but
"ogrinfo --ro GIS.gdb" does not list them.
(In case anyone is interested, the data is from here:
https://itportal.decc.gov.uk/web_files/gis/Round30Data/Getech/UKCS_Multi_Sat_Gravity_Data.zip
and is referenced from here:
http://data-ogauthority.opendata.arcgis.com/datasets
Both the ESRI and GIS sub-directories contain .gdb sub-directories. The
ESRI sub-directory GDB apparently contains only grids; the GDB in the GIS
sub-directory has two MultiPolygon layers and about ten grids.)
Thanks for any suggestions,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/97e527f0/attachment.html>
