[gdal-dev] OSM conversion failure
Even Rouault
even.rouault at spatialys.com
Tue Jul 25 12:03:54 PDT 2017
On mardi 25 juillet 2017 16:36:17 CEST Tim Harris wrote:
> I placed a small test file here:
> https://s3.amazonaws.com/osm-test-data/test.pbf
> With the latest trunk, when I run this command:
> ogr2ogr test.shp test.pbf multipolygons
> The result shapefile I get appears to be empty. I've also tried with release
> 2.1.2 and that result shapefile is not empty. So it seems like some recent
> change may have broken the OSM driver.
Indeed. Thanks for the report. Fixed by r39666 + r39667
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/c39c330e/attachment.html>
