[gdal-dev] OSM conversion failure
Tim Harris
Tim.Harris at digitalglobe.com
Tue Jul 25 10:16:16 PDT 2017
By the way, it looks like this works fine with an XML .osm file, just not the binary .pbf.
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Tim Harris
Sent: Tuesday, July 25, 2017 10:36 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] OSM conversion failure
I placed a small test file here: https://s3.amazonaws.com/osm-test-data/test.pbf
With the latest trunk, when I run this command:
ogr2ogr test.shp test.pbf multipolygons
The result shapefile I get appears to be empty. I've also tried with release 2.1.2 and that result shapefile is not empty. So it seems like some recent change may have broken the OSM driver.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170725/b9d886fb/attachment-0001.html>
