[gdal-dev] Rasterize Inmem vector
Johan de Braak johan.de.braak at eleaf.com
Mon Jul 31 07:31:05 PDT 2017
Hi all,
How would I rasterize an in memory vector? I have tried this:
    assert isinstance(inmemds, ogr.DataSource), 'inmemds is not a ogr
DataSource' #assert not triggered
    rastoptions = gdal.RasterizeOptions(outputType=gdal.GDT_Byte,
burnValues=1, xRes=100, yRes=100)
    ds = gdal.Rasterize('/vsimem/tmp_{}'.format(uuid4().hex), inmemds,
options=rastoptions)
gives:
    TypeError: in method 'wrapper_GDALRasterizeDestName', argument 2 of type
'GDALDatasetShadow *'
The docstring of gdal.Rasterize says the following:
    Arguments are :
      destNameOrDestDS --- Output dataset name or object
      srcDS --- a Dataset object or a filename
So srcDS can be a Dataset, right? As I missing something?
Regards,
Johan
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rasterize-Inmem-vector-tp5329885.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
