[gdal-dev] Rasterize Inmem vector
Even Rouault
even.rouault at spatialys.com
Mon Jul 31 07:42:22 PDT 2017
On lundi 31 juillet 2017 07:31:05 CEST Johan de Braak wrote:
> Hi all,
> How would I rasterize an in memory vector? I have tried this:
> assert isinstance(inmemds, ogr.DataSource), 'inmemds is not a ogr
> DataSource' #assert not triggered
> rastoptions = gdal.RasterizeOptions(outputType=gdal.GDT_Byte,
> burnValues=1, xRes=100, yRes=100)
> ds = gdal.Rasterize('/vsimem/tmp_{}'.format(uuid4().hex), inmemds,
> options=rastoptions)
> gives:
> TypeError: in method 'wrapper_GDALRasterizeDestName', argument 2 of type
> 'GDALDatasetShadow *'
> The docstring of gdal.Rasterize says the following:
> Arguments are :
> destNameOrDestDS --- Output dataset name or object
> srcDS --- a Dataset object or a filename
> So srcDS can be a Dataset, right? As I missing something?
Yes, srcDS must be a gdal.Dataset, not a ogr.DataSource
so use gdal.GetDriverByName("Memory").Create("", 0, 0, 0, gdal.GDT_Unknown) to create it
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170731/0a93b2cc/attachment.html>
