[gdal-dev] CSV to GeoRSS: problem with pubDate field
aborruso
aborruso at gmail.com
Mon Jul 31 10:37:41 PDT 2017
I'm using GDAL 2.3.0dev to convert a CSV to GeoRSS, but I'm not able to set
properly pubDate field.
My test input CSV is (tab separated):
title description guid link pubDate
titolo des http://www.tin.it/1 http://www.tin.it/1 Wed, 11 Jul 2007 15:39:21
GMT
I run:
ogr2ogr -f GeoRSS georss.xml source.csv source
And I have "ERROR 1: Wrong field type for pubDate" error and this XML
output:
<?xml version="1.0"?>
<rss version="2.0" xmlns:georss="http://www.georss.org/georss">
<channel>
<title>title</title>
<description>channel_description</description>
<link>channel_link</link>
<item>
<title>titolo</title>
<description>des</description>
<guid>http://www.tin.it/1</guid>
<link>http://www.tin.it/1</link>
</item>
</channel>
</rss>
It's almost perfect, but without pubDate. How to set it in my source CSV?
Thank you,
Andrea
View this message in context: http://osgeo-org.1560.x6.nabble.com/CSV-to-GeoRSS-problem-with-pubDate-field-tp5329925.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
