[gdal-dev] Gdal and Open Data Cube
Peter Baumann
p.baumann at jacobs-university.de
Mon Jun 12 04:24:23 PDT 2017
Hi Julien,
understood, a particular project will usually have particular constraints, no
problem. Actually, should you be willing to undertake this ODC endeavour maybe
you can post a summary of functionality and performance comparison here
afterwards? Might be interesting for some.
best,
Peter
On 06/12/2017 11:55 AM, Julien Michel wrote:
> Hi Peter,
> I know about rasdaman, I even attended the rasdaman tutorial at FOSS4GEU 2015.
> But my point is not to choose or compare implementations : I am working with a
> project that uses the this ODC, I want to be able to do some OTB processing
> with it, and OTB reads data through gdal. And from a gdal perspective, it
> makes sense to have drivers for every possible (open-source) data source.
> Hence my question. I am a bit worried about the overhead of what Even sketched ;)
> Regards,
> Julien
> Le 04/06/2017 à 15:09, Peter Baumann a écrit :
>> Hi Julien,
>> already seen rasdaman (www.rasdaman.org)? Fully implemented nD datacube engine,
>> proven on massive data, in operational use (not just planning phase)...and
>> proudly using GDAL.
>> As I am editor of the OGC datacube standards I'll be glad to give advice on
>> standards-based coupling. Just le me know your plans.
>> cheers,
>> Peter
>> On 06/02/2017 02:28 PM, Julien Michel wrote:
>>> Dear all,
>>> There is a lot of activity around this Open Data Cube [1] initiative, which
>>> seems promising. As far as I understand it however, what we can do with data
>>> in the datacube is limited to what the python API allows you to do. Is there
>>> any plan (and does it even make sense ?) to have a gdal driver that allows to
>>> address data ingested in a datacube instance ?
>>> Thanks a lot,
>>> Regards,
>>> Julien
>>> [1] https://github.com/opendatacube/datacube-core
Dr. Peter Baumann
- Professor of Computer Science, Jacobs University Bremen
www.faculty.jacobs-university.de/pbaumann
mail: p.baumann at jacobs-university.de
tel: +49-421-200-3178, fax: +49-421-200-493178
- Executive Director, rasdaman GmbH Bremen (HRB 26793)
www.rasdaman.com, mail: baumann at rasdaman.com
tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
