[gdal-dev] Gdal and Open Data Cube
    Julien Michel
    julien.michel at cnes.fr
    Mon Jun 12 02:55:16 PDT 2017
Hi Peter,
I know about rasdaman, I even attended the rasdaman tutorial at FOSS4GEU
2015. But my point is not to choose or compare implementations : I am
working with a project that uses the this ODC,  I want to be able to do
some OTB processing with it, and OTB reads data through gdal. And from a
gdal perspective, it makes sense to have drivers for every possible
(open-source) data source. Hence my question. I am a bit worried about
the overhead of what Even sketched ;)
Regards,
Julien
Le 04/06/2017 à 15:09, Peter Baumann a écrit :
> Hi Julien,
> already seen rasdaman (www.rasdaman.org)? Fully implemented nD datacube engine,
> proven on massive data, in operational use (not just planning phase)...and
> proudly using GDAL.
> As I am editor of the OGC datacube standards I'll be glad to give advice on
> standards-based coupling. Just le me know your plans.
> cheers,
> Peter
> On 06/02/2017 02:28 PM, Julien Michel wrote:
>> Dear all,
>> There is a lot of activity around this Open Data Cube [1] initiative, which
>> seems promising. As far as I understand it however, what we can do with data
>> in the datacube is limited to what the python API allows you to do. Is there
>> any plan (and does it even make sense ?) to have a gdal driver that allows to
>> address data ingested in a datacube instance ?
>> Thanks a lot,
>> Regards,
>> Julien
>> [1] https://github.com/opendatacube/datacube-core
Julien MICHEL
CNES - DSO/SI/2A - BPI 1219
18, avenue Edouard Belin
31401 Toulouse Cedex 09 - France
Tel: +33 561 282 894 - Fax: +33 561 283 109
