[gdal-dev] Raster calculation optimalisation
Damian Dixon
damian.dixon at gmail.com
Tue Jun 13 06:05:03 PDT 2017
Hi Paul,
What is the time to run your code without applying the calculation to each
pixel?
It is usually better to process the pixels in a block rather than walking
across each row especially if you are processing a TIFF as these are
usually stored as tiles (blocks).
The crossing from C# to C++ will also impact the performance so take a look
at the time it takes to set the pixels. There may also be a method to set a
block of pixels.
Sorry I can't help you more than some general advice and hints.
Regards
Damian
On 13 June 2017 at 12:20, Paul Meems <bontepaarden at gmail.com> wrote:
> I'm using GDAL v2.1.3 with the SWIG bindings in my custom C# application.
> I've created a method to do some calculation of my raster file:
> public bool GdalCalculate(string input, string output, string formula,
> double? minValue = null)
> if (!File.Exists(input))
> throw new FileNotFoundException("Can't find the input file", new
> Exception("Working with " + input));
> // 1. First copy the input file to create the output file
> try
> /* Get driver
> using (var drv = Gdal.GetDriverByName("GTiff"))
> if (drv == null)
> throw new Exception("Can't get GTiff driver");
> /* Open dataset.
> using (var ds = Gdal.Open(input, Access.GA_ReadOnly))
> if (ds == null)
> throw new Exception("Can't open GDAL dataset: " +
> input);
> var options = new[] { "" };
> using (var newDataset = drv.CreateCopy(output, ds, 0,
> options, null, "Sample Data"))
> if (newDataset == null)
> throw new Exception("Can't create destination
> dataset: " + output);
> // Close input dataset:
> ds.Dispose();
> // 2. Loop through all pixels and perform formula on
> it:
> using (var band = newDataset.GetRasterBand(1))
> double noData;
> int hasValue;
> band.GetNoDataValue(out noData, out hasValue);
> var sizeX = band.XSize;
> var numLines = band.YSize;
> var func = new Function("f(A) = " + formula);
> // Loop through each line in turn.
> for (var line = 0; line < numLines; line++)
> var scanline = new float[sizeX];
> // Read in data for the current line
> var cplReturn = band.ReadRaster(0, line,
> sizeX, 1, scanline, sizeX, 1, 0, 0);
> if (cplReturn != CPLErr.CE_None)
> throw new Exception("band.ReadRaster
> failed: " + Gdal.GetLastErrorMsg());
> var outputLine = new List<float>();
> foreach (var f in scanline)
> var pixelValue = f;
> if ((float)f != (float)noData)
> // Calculate
> pixelValue = (float)func.calculate(f);
> if (minValue.HasValue)
> pixelValue =
> (float)Math.Max(pixelValue, minValue.GetValueOrDefault());
> outputLine.Add(pixelValue);
> // Rewrite line:
> cplReturn = band.WriteRaster(0, line, sizeX,
> 1, outputLine.ToArray(), sizeX, 1, 0, 0);
> throw new Exception("band.WriteRaster
> // 3. Save changes to file:
> band.FlushCache();
> newDataset.FlushCache();
> catch (Exception e)
> throw new Exception("Can't open GDAL dataset: " + input, e);
> return true;
> This method is working fine, but is very slow.
> I'm using a 3621x4466 tiff file, which has a size of 67MB.
> It is taking around 10 minutes to process.
> (float)func.calculate(f); is using http://mathparser.org/
> An example of a function I'm using: 9.7E-05-e^(3.1 + 0.9 * A) where A is
> the pixel value.
> How can I optimize my function?
> Thanks,
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170613/14daa79e/attachment-0001.html>
