[gdal-dev] Raster calculation optimalisation
Damian Dixon damian.dixon at gmail.com
Tue Jun 13 06:36:11 PDT 2017
​Hi Paul,
I can only do snippets in C++...
You can get the block size using:
  poBand->GetBlockSize( &nBlockXSize, &nBlockYSize );
then do a read something like:
  for(int band = 0; band <noBands;band++)
poBand[0]->AdviseRead(startX+xoffset,startY+yoffset,blockWidth,blockHeight,blockWidth,blockHeight,GDT_Int32,
NULL);
    CPLErr err =
poBand[band]->RasterIO(GF_Read,startX+xoffset,startY+yoffset,blockWidth,blockHeight,buffer[band],blockWidth,blockHeight,GDT_Int32,0,0);
    if(err != CE_None)
      report an error
I don't normally put raster back into GDAL we just use GDAL to read data
and do all the processing ourselves.
I suspect all you have to do is change GF_Read to GF_Write and a few other
tweaks :>>.
Regards
Damian
The following page may be of help: http://www.gdal.org/gdal_tutorial.html
On 13 June 2017 at 14:19, Paul Meems <bontepaarden at gmail.com> wrote:
> Thanks Damian for your hint.
> I'll try in a minute without the formula.
> You mention process the pixels in a block. How would I do that? Do you
> have an example?
> Thanks,
> Paul
> 2017-06-13 15:05 GMT+02:00 Damian Dixon <damian.dixon at gmail.com>:
>> Hi Paul,
>> What is the time to run your code without applying the calculation to
>> each pixel?
>> It is usually better to process the pixels in a block rather than walking
>> across each row especially if you are processing a TIFF as these are
>> usually stored as tiles (blocks).
>> The crossing from C# to C++ will also impact the performance so take a
>> look at the time it takes to set the pixels. There may also be a method to
>> set a block of pixels.
>> Sorry I can't help you more than some general advice and hints.
>> Regards
>> Damian
>> On 13 June 2017 at 12:20, Paul Meems <bontepaarden at gmail.com> wrote:
>>> I'm using GDAL v2.1.3 with the SWIG bindings in my custom C# application.
>>> I've created a method to do some calculation of my raster file:
>>> public bool GdalCalculate(string input, string output, string formula,
>>> double? minValue = null)
>>>     if (!File.Exists(input))
>>>         throw new FileNotFoundException("Can't find the input file", new
>>> Exception("Working with " + input));
>>>     // 1. First copy the input file to create the output file
>>>     try
>>>         /*      Get driver
>>>         using (var drv = Gdal.GetDriverByName("GTiff"))
>>>             if (drv == null)
>>>                 throw new Exception("Can't get GTiff driver");
>>>             /*      Open dataset.
>>>             using (var ds = Gdal.Open(input, Access.GA_ReadOnly))
>>>                 if (ds == null)
>>>                     throw new Exception("Can't open GDAL dataset: " +
>>> input);
>>>                 var options = new[] { "" };
>>>                 using (var newDataset = drv.CreateCopy(output, ds, 0,
>>> options, null, "Sample Data"))
>>>                     if (newDataset == null)
>>>                         throw new Exception("Can't create destination
>>> dataset: " + output);
>>>                     // Close input dataset:
>>>                     ds.Dispose();
>>>                     // 2. Loop through all pixels and perform formula on
>>> it:
>>>                     using (var band = newDataset.GetRasterBand(1))
>>>                         double noData;
>>>                         int hasValue;
>>>                         band.GetNoDataValue(out noData, out hasValue);
>>>                         var sizeX = band.XSize;
>>>                         var numLines = band.YSize;
>>>                         var func = new Function("f(A) = " + formula);
>>>                         // Loop through each line in turn.
>>>                         for (var line = 0; line < numLines; line++)
>>>                             var scanline = new float[sizeX];
>>>                             // Read in data for the current line
>>>                             var cplReturn = band.ReadRaster(0, line,
>>> sizeX, 1, scanline, sizeX, 1, 0, 0);
>>>                             if (cplReturn != CPLErr.CE_None)
>>>                                 throw new Exception("band.ReadRaster
>>> failed: " + Gdal.GetLastErrorMsg());
>>>                             var outputLine = new List<float>();
>>>                             foreach (var f in scanline)
>>>                                 var pixelValue = f;
>>>                                 if ((float)f != (float)noData)
>>>                                     // Calculate
>>>                                     pixelValue =
>>> (float)func.calculate(f);
>>>                                     if (minValue.HasValue)
>>>                                         pixelValue =
>>> (float)Math.Max(pixelValue, minValue.GetValueOrDefault());
>>>                                 outputLine.Add(pixelValue);
>>>                             // Rewrite line:
>>>                             cplReturn = band.WriteRaster(0, line, sizeX,
>>> 1, outputLine.ToArray(), sizeX, 1, 0, 0);
>>>                                 throw new Exception("band.WriteRaster
>>>                         // 3. Save changes to file:
>>>                         band.FlushCache();
>>>                         newDataset.FlushCache();
>>>     catch (Exception e)
>>>         throw new Exception("Can't open GDAL dataset: " + input, e);
>>>     return true;
>>> This method is working fine, but is very slow.
>>> I'm using a 3621x4466 tiff file, which has a size of 67MB.
>>> It is taking around 10 minutes to process.
>>> (float)func.calculate(f); is using http://mathparser.org/
>>> An example of a function I'm using: 9.7E-05-e^(3.1 + 0.9 * A) where A
>>> is the pixel value.
>>> How can I optimize my function?
>>> Thanks,
>>> Paul
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170613/5f7fb741/attachment-0001.html>
