[gdal-dev] Calling GDAL directly from within Python
Rutger
kassies at gmail.com
Wed Jun 14 06:36:24 PDT 2017
Hey,
To start with a side note, your GDAL version of 3.0.8 doesn't make much
sense. The utilities from the bindings are available since 2.1 if I'm
correct, and the latest release is 2.2. Doesn't matter though.
The text about "GRIB" you are seeing is only the name of the coordinate
system, 'gdal.Translate' simply copies this projection to the TIFF file. Its
a bit confusing indeed. The name probably comes from GDAL's GRIB driver, or
some library it uses.
Your call to gdal.Translate appears to work fine, although its always good
to check if the projection, extent etc are correct. And preferably also find
some documentation from the data provider to confirm.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Calling-GDAL-directly-from-within-Python-tp5324036p5324191.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
