[gdal-dev] Overcome attribute name limitation in shapefiles
Even Rouault even.rouault at spatialys.com
Tue Mar 7 01:35:29 PST 2017
On mardi 7 mars 2017 09:17:50 CET Felix Obermaier wrote:
> Peter,
> why would it cease to respect the dBaseIV Standard? I’m not proposing a
> change regarding the dBase format but an additional file that gives
> additional information the data in the attribute column. If you don’t
> supply that file you don’t have the additinal information, but you still
> can access the data and have to figure out by yourself what it is.
> I know that there are other data sources that are not limited in the size
> for column names that I can use. But often I’m asked „Can you provide me a
> Shapefile“ and then I’m sometimes stuck with column names that are
> abbreviated to undistinctness.
 Or I get a shapefile of that kind, which
> does not make it any better.
> Felix
> Von: Peter Halls [mailto:p.halls at york.ac.uk]
> Gesendet: Montag, 6. März 2017 14:56
> An: Felix Obermaier <obe at IVV-AACHEN.DE>; gdal dev
> <gdal-dev at lists.osgeo.org>
 Betreff: Re: [gdal-dev] Overcome attribute name
> Felix,
>       following your proposal would make Shapefiles cease to respect the
> dBaseIV Standard and potentially seriously affect their interchangability.
> There are a range of alternative formats supported by GDAL that achieve
> your goal: for example, I use SQL as my base format and only convert when
> necessary.  SQL is generally accepted by other packages and is far more
> flexible than dBaseIV.
 Best wishes,
> Peter
> On 6 March 2017 at 13:26, Felix Obermaier
> <obe at ivv-aachen.de<mailto:obe at ivv-aachen.de>> wrote:
 Hello,
> is it somehow possible to overcome the attribute name length limitiation of
> DBase files using GDAL? If so, how?
> If not, why not add (another) file the shapefile dataset of shapes (shp,
> shx), projection (prj), data (dbf) and encoding(cpg), one that is (re-)
> defining the column names, allowing for
>   *   mixed casing,
>   *   non-ASCII characters,
>   *   more than 10/11 characters
> I’m aware of a software product that does it this way. The file that renames
> the columns is set up like a CSV file defining two columns, „Name“ and
> „Alias“. „Name“ is the actual name of the column, „Alias“ the name in the
> dbase file header.
What is this software that produces this sidecar CSV-like format ? Could you show examples
of such datasets ?
> Felix Obermaier
> Ingenieurgruppe IVV GmbH & Co. KG
> Dipl.-Ing. Felix Obermaier
> Oppenhoffallee 171
> 52066 Aachen
> Telefon: +49 (241) 94691-39<tel:+49%20241%209469139>
> Telefax: +49 (241) 531622<tel:+49%20241%20531622>
> eMail: obe at ivv-aachen.de<mailto:obe at ivv-aachen.de>
> Internet: http://www.ivv-aachen.de
> Sitz der Gesellschaft: Aachen
> Amtsgericht Aachen HRA 6212
> Geschäftsführer:
> Dipl.-Ing. Wolfgang Hölsken
> Dr.-Ing. Stephan Krug
> Dr.-Ing. Dirk Serwill
> IVV-Management GmbH
> Amtsgericht Aachen HRB 12453
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
 Peter J Halls, Post-war Reconstruction
> and Development Unit (PRDU), University of York
> Snail mail: c/o Research Centre for the Social Sciences (RCSS),
>         University of York,
>         Heslington, York YO10 5DD
> This message has the status of a private and personal communication
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170307/73122c1c/attachment.html>
