[gdal-dev] sqlite -> spatialite (rowid)
Even Rouault
even.rouault at spatialys.com
Tue Mar 7 04:41:48 PST 2017
Martin,
This error is emitted by spatialite.
See
https://www.gaia-gis.it/fossil/libspatialite/wiki?name=Shadowed+ROWID+issues
Did you check that the FID column name of your input table wasn't rowid ?
I could reproduce by forging first such a DB
$ ogrinfo test.db -al -so
INFO: Open of `test.db'
using driver `SQLite' successful.
Layer name: test
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
FID Column = rowid <-- see
Geometry Column = GEOMETRY
Then:
$ ogr2ogr test2.db test.db -dsco spatialite=yes -f sqlite
CreateSpatialIndex() error: a physical column named ROWID shadows the real ROWID
Workaround :
$ ogr2ogr test2.db test.db -dsco spatialite=yes -f sqlite -lco fid=my_rowid
I think that Spatialite's validateRowid() fuction should be patched to check if the rowid
column is not of type INTEGER PRIMARY KEY, if so that's acceptable, instead of just checking
for rowid. CC'ing Sandro.
Even
On mardi 7 mars 2017 13:10:32 CET Martin Landa wrote:
> Hi,
> recently I discovered strange behaviour when converting SQLite
> database to Spatialite:
> ogr2ogr -f SQLite -dsco SPATIALITE=YES Export_vse.sdb Export_vse.db
> ROWID
> The output table contains rowid column even input table doesn't not
> contain such column. It seems that this column is created by GDAL when
> converting data into Spatialite DB, is it possible?
> Thanks, Martin
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170307/37d17521/attachment.html>
