[gdal-dev] OpenFileGDB driver conflicts with GPX and KML driver
Even Rouault even.rouault at spatialys.com
Fri Mar 10 09:03:22 PST 2017
On vendredi 10 mars 2017 13:35:18 CET Holger Schiebold wrote:
> Hi all,
> at gdal 1.11.5 i have to disable via OGR_SKIP the GPX and KML driver to
> get FileGDB driver working with my ESRI filegeodatabases. Otherwise i
> get an segfault caused by the GPX or KML driver.  On former 1.9 version
> of gdal this not happens.
The OpenFileGDB driver didn't exist at that time ;-)
> Is it a bug or special circumstances in my
> environment? Can anybody confirm that behaviour in his environment?
I'm not aware of issues like the one you report. Does that happen with all .gdb or a particular
one ? It would be interesting to know if it still happens for you in recent releases since 1.11 is
aging now.
Even
> thanks in advance
> Holger
> mit freundlichen Grüßen
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170310/2a8bcd52/attachment.html>
