[gdal-dev] Transformation of a vertical datum
Even Rouault
even.rouault at spatialys.com
Thu Mar 16 09:21:35 PDT 2017
On jeudi 16 mars 2017 16:57:11 CET OpenDEM wrote:
> Hi,
> I would like to transform the vertical datum EPSG:5730 to EPSG:5621
> For more information about the European height reference systems have a look
> at: http://www.crs-geo.eu/
> I used gdaltransform, but the z value is not changing:
Yes, I you look at the output of gdalsrsinfo on both SRS, you'll see that there is no explicit
vertical shift grid mentionned (+geoidgrids=something paramet in proj.4 string). Thus no
vertical shift is done. So, you should look if there are vertical shift grids betwen EVRF2005
&/ EVRF2000 and WGS84 ellipsoidal height, so that they can be used with proj.4
$ gdalsrsinfo EPSG:3035+5621
PROJ.4 : '+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +ellps=GRS80
+towgs84=0,0,0,0,0,0,0 +units=m +vunits=m +no_defs '
OGC WKT :
COMPD_CS["ETRS89 / LAEA Europe + EVRF2007 height",
PROJCS["ETRS89 / LAEA Europe",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3035"]],
VERT_CS["EVRF2007 height",
VERT_DATUM["European Vertical Reference Frame 2007",2005,
AUTHORITY["EPSG","5215"]],
UNIT["metre",1,
AXIS["Up",UP],
AUTHORITY["EPSG","5621"]]]
On the contrary :
$ gdalsrsinfo EPSG:3035+5773
+towgs84=0,0,0,0,0,0,0 +units=m +geoidgrids=egm96_15.gtx +vunits=m +no_defs '
OGC WKT :
COMPD_CS["ETRS89 / LAEA Europe + EGM96 geoid height",
GEOGCS["ETRS89",
UNIT["metre",1,
VERT_CS["EGM96 geoid height",
VERT_DATUM["EGM96 geoid",2005,
EXTENSION["PROJ4_GRIDS","egm96_15.gtx"],
AUTHORITY["EPSG","5171"]],
UNIT["metre",1,
AXIS["Up",UP],
AUTHORITY["EPSG","5773"]]]
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170316/b05abe6a/attachment.html>
