[gdal-dev] Transformation of a vertical datum
OpenDEM contact at opendemdata.info
Mon Mar 20 13:03:55 PDT 2017
Hi Even,
Thanks for your reply.
Unfortunately there are no shift grids available yet, but I contacted
CRS-EU.
They want to discuss this topic at the next EUREF meeting.
Best,
Martin
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Donnerstag, 16. März 2017 17:22
To: gdal-dev at lists.osgeo.org
Cc: OpenDEM
Subject: Re: [gdal-dev] Transformation of a vertical datum
On jeudi 16 mars 2017 16:57:11 CET OpenDEM wrote:
> Hi,
> I would like to transform the vertical datum EPSG:5730 to EPSG:5621
> For more information about the European height reference systems have a
look
> at:  <http://www.crs-geo.eu/> http://www.crs-geo.eu/
> I used gdaltransform, but the z value is not changing:
Yes, I you look at the output of gdalsrsinfo on both SRS, you'll see that
there is no explicit vertical shift grid mentionned (+geoidgrids=something
paramet in proj.4 string). Thus no vertical shift is done. So, you should
look if there are vertical shift grids betwen EVRF2005 &/ EVRF2000 and WGS84
ellipsoidal height, so that they can be used with proj.4
$ gdalsrsinfo EPSG:3035+5621
PROJ.4 : '+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +vunits=m +no_defs '
OGC WKT :
COMPD_CS["ETRS89 / LAEA Europe + EVRF2007 height",
PROJCS["ETRS89 / LAEA Europe",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3035"]],
VERT_CS["EVRF2007 height",
VERT_DATUM["European Vertical Reference Frame 2007",2005,
AUTHORITY["EPSG","5215"]],
UNIT["metre",1,
AXIS["Up",UP],
AUTHORITY["EPSG","5621"]]]
On the contrary :
$ gdalsrsinfo EPSG:3035+5773
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +geoidgrids=egm96_15.gtx
OGC WKT :
COMPD_CS["ETRS89 / LAEA Europe + EGM96 geoid height",
GEOGCS["ETRS89",
UNIT["metre",1,
VERT_CS["EGM96 geoid height",
VERT_DATUM["EGM96 geoid",2005,
EXTENSION["PROJ4_GRIDS","egm96_15.gtx"],
AUTHORITY["EPSG","5171"]],
UNIT["metre",1,
AXIS["Up",UP],
AUTHORITY["EPSG","5773"]]]
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170320/636cad96/attachment-0001.html>
